BT/VC UPDATE
paxtonix
BT/VC UPDATE
Post by paxtonix »
Files for Bluetooth /Voice Control USB Firmware
Code: Select all
Release: November 2012
The update to your Ford Bluetooth and multimedia module provides you with improvements in the following areas:
- Improved energy management in connection with USB and Bluetooth devices
Release: April 2012
- Playback of music files via the USB stick
- Connection stability of iPod/iPhone devices
- Connection stability for Bluetooth, telephony and music streaming via Bluetooth
- Compatibility of mobile phones
Release: October 2011
- Supports the original Apple USB cable
- Apple iOS 5 compatibility: display of the phones battery level and signal strenght
- Apple iOS 5 compatibility: improved stability for music streaming via Bluetooth
- Display of phone book and call lists
This update is applicable to the following vehicles:
Model    Built date
Fiesta:  July       2008 - December 2011
Focus:   February   2008 - January 2012
C-MAX:   February   2008 - January 2012
Kuga:    February   2008 - January 2012
Mondeo:  September  2008 - January 2012
S-MAX:   September  2008 - January 2012
Galaxy:  September  2008 - January 2012
Transit: from June  2009
Ranger:  from April 2009
1.Format a USB memory stick, ensuring the file system is set to FAT32. If update somehow does not start , try formating to FAT/FAT16
2.Unzip the contents (all 21 items) of the zip file, and copy them to the root of the memory stick, i.e. without placing them in any folders. The contents of the memory stick should appear in "root" as loose files.
Tourist
Gwe89
Re: BT/VC UPDATE
Post by Gwe89 »
tasicky
Starter
Re: BT/VC UPDATE
Post by tasicky »
Its possible to flash it via UCDS or JTag?
Firmware update fail. Module starting after reset and after fiew seconds going off.
Re: BT/VC UPDATE
Also looking for a way to do it directly (e.g. JTAG) but not luck until now. See me notes on this thread about hardware-repairing a bricked BT-module: viewtopic.php?f=29&t=48
ronald0001
Re: BT/VC UPDATE
Post by ronald0001 »
is there a way to change language with update for voice control?
english to german as example?
getsome
Re: BT/VC UPDATE
Post by getsome »
I think to change language you have to change this in the central config , if this is even an option at all ?
amplified
Re: BT/VC UPDATE
Post by amplified »
no, changing it in central config doesn't change the language as it's in the firmware. Only with NX or MCA you can change the language as it's in the nav and uses the bt module just for the mic.
Anybody successfully changed the firmware with other lang on this via ucds or jtag?
User avatar
Stevebe
Re: BT/VC UPDATE
Post by Stevebe »
Built a reader/ writer for the gt25c64 eeprom which has. UFdn base
I used a modified click board as it was the cheapest source of a UFDN socket
Digimod
Re: BT/VC UPDATE
Nice job. As i experimented with it (because i suspected it to be the cause of the boot fault8 i found out that one could replace it by a standard Eeprom by desoldering the part and find points on the pcb to solder wires onto.
But the eeprom content simply get's repopulated each time the module starts, if it is empty. So it seems is of no use in repairing the unit (like on satnav radios).
marekrbk
Re: BT/VC UPDATE
Post by marekrbk »
bt update with forscan works
