read radio serial code blaupunkt travel pilot FX
tomy75
Post by tomy75 »
hello
i need help
im change general board in travelpilot fx
i dont have radio serial code to unlock radio
can i read from board radio serial code?
thenx
tomas
Re: read radio serial code blaupunkt travel pilot FX
Of course you can. First of all, do you still have the old board? What was wrong with it?
If you have the old board you may be able to copy the sector to your new board.
With Segger J-Link, read sector #251 (Start 0x1F60000, len 0x2000). Within this sector you find the Bosch type number (7612...) and the 7 digit serial number. You find the memory locations within this sector here https://mk4-wiki.denkdose.de/artikel/na ... memory_map
With those two numbers at hand you can use my calculator here to get the PIN https://mk4-wiki.denkdose.de/artikel/na ... _decryptor
tomy75
Post by tomy75 »
hello Go4IT
thenx
my old board no working,i dont no
i dont have segger j-link
its other possibility?
t.
Go4IT wrote: 03 Oct 2019, 16:27 Of course you can. First of all, do you still have the old board? What was wrong with it?
No, unfortunately not. The new board, where does it come from? If the seller could give you a picture of the side label of the device he has ripped it of - there you find the above mentioned informations needed for calcing the PIN. If not, there is NO CHANCE to get the right code as to read out the Flash with Segger. You may send it to me or anybody else can do this.
But answer my question: Do you still have the old board? I guess it broke and suddenly stopped working. Then it's the broken RAMs, need to be replaced to get it working again. I did this repair many times.
tomy75
Post by tomy75 »
thenx
im change 2*RAM and no working
my neu board buy in stock market
only board,no picture of the side label
t.
Go4IT wrote: 03 Oct 2019, 19:17 No, unfortunately not. The new board, where does it come from? If the seller could give you a picture of the side label of the device he has ripped it of - there you find the above mentioned informations needed for calcing the PIN. If not, there is NO CHANCE to get the right code as to read out the Flash with Segger. You may send it to me or anybody else can do this.
There are some issues where the board does not start but the RAMs are not the problem... i wrote about this here. But, the reason i'm asking is, that if you had a Segger JLink you could try to copy the PIN relevant sector over to your now board and build this into the case of the old one. So everything fits, even the serial on the label :-)
But, without an JTAG reader you have NO chance to do this repair, sorry.
tomy75
Post by tomy75 »
hello
thanks Go4it
ou an repait m old board?IM FOROM slovakia and you?
i need for traelpilot FX slovak language pack
Can you help me?
thanks
tomas
Go4IT wrote: 04 Oct 2019, 14:23 There are some issues where the board does not start but the RAMs are not the problem... i wrote about this here. But, the reason i'm asking is, that if you had a Segger JLink you could try to ccopy the PIN relevant sector over to your now board and build this into the case of the old one. So everything fits, even the serial on the label :-)
Artist
Post by Artist »
Won't you be surprised if go4it is from Germany?
SK lang pack not exist.
There is only Czech pack. Unfortunately no one will ever give it to you. The sooner you do it the better you sleep ...
tomy75
Post by tomy75 »
I have Polish pack,im change to Czech pack
Artist wrote: 04 Oct 2019, 19:40 Won't you be surprised if go4it is from Germany?
tomy75
Post by tomy75 »
With elmconfig program im read rádio serial number
I have elm327 cabel
See photo
Thenx
Go4IT wrote: 04 Oct 2019, 14:23 There are some issues where the board does not start but the RAMs are not the problem... i wrote about this here. But, the reason i'm asking is, that if you had a Segger JLink you could try to copy the PIN relevant sector over to your now board and build this into the case of the old one. So everything fits, even the serial on the label :-)
