Gwe89
Posts: 335 Joined: 09 Feb 2019, 21:21
Post
by Gwe89 » 28 May 2022, 20:34
Hi guys having a few issues after fitting PBM
I have a few errors I cannot get rid of
Ford smax 2012 2.0tdci
The clutch switch error goes if I set it back to manual parking brake so definitely not the clutch switch
I possibly think this is down to the abs config but in forscan I don't know what all these options are can anyone help
Gwe89
Post
by Gwe89 » 30 May 2022, 11:14
im guessing this sensor is only for autos/powershift?
Gwe89
Post
by Gwe89 » 30 May 2022, 13:34
I have noticed it's also messed with my ACC because it now puts it on standby when I change gear, also it seems to be making it over rev when I press the clutch
ZvonimirG
Starter
Posts: 44 Joined: 21 Jun 2021, 17:23
Post
by ZvonimirG » 31 May 2022, 10:06
Gwe89 wrote: ↑ 30 May 2022, 11:14
Auto / power shift don't have clutch cylinder.
So that sensor must be for manual transmission because he is located on master cylinder ford part no 1801417
Gwe89
Post
by Gwe89 » 31 May 2022, 17:05
ZvonimirG wrote: ↑ 31 May 2022, 10:06
Thank you so I'm guessing I need this for pbm to work properly
Gwe89
Post
by Gwe89 » 31 May 2022, 17:06
ZvonimirG
Starter
Post
by ZvonimirG » 31 May 2022, 17:59
Gwe89 wrote: ↑ 31 May 2022, 17:06
I guess that is needed for auto realase of parking brake.
Maybe is possible to disable auto release trough CCC?
Gwe89
Post
by Gwe89 » 31 May 2022, 18:20
ZvonimirG wrote: ↑ 31 May 2022, 17:59
Yes you can but still get clutch sensor fault
Gwe89
Post
by Gwe89 » 02 Jun 2022, 17:02
So I have found the plug now to get a sensor
Gwe89
Post
by Gwe89 » 02 Oct 2023, 05:46
Still trying to get to the bottom of a fault code I have after fitting pbm U3000:00-2F can anyone help please?
