PBM RetroFit
Gwe89
Pro
PBM RetroFit
Post by Gwe89 »
Hi guys having a few issues after fitting PBM
I have a few errors I cannot get rid of
Ford smax 2012 2.0tdci
The clutch switch error goes if I set it back to manual parking brake so definitely not the clutch switch
I possibly think this is down to the abs config but in forscan I don't know what all these options are can anyone help
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
im guessing this sensor is only for autos/powershift?
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
I have noticed it's also messed with my ACC because it now puts it on standby when I change gear, also it seems to be making it over rev when I press the clutch
ZvonimirG
Starter
Re: PBM RetroFit
Post by ZvonimirG »
Gwe89 wrote: 30 May 2022, 11:14 im guessing this sensor is only for autos/powershift?
Auto / power shift don't have clutch cylinder.
So that sensor must be for manual transmission because he is located on master cylinder ford part no 1801417
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
ZvonimirG wrote: 31 May 2022, 10:06
Thank you so I'm guessing I need this for pbm to work properly
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
ZvonimirG
Starter
Re: PBM RetroFit
Post by ZvonimirG »
Gwe89 wrote: 31 May 2022, 17:06
I guess that is needed for auto realase of parking brake.
Maybe is possible to disable auto release trough CCC?
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
ZvonimirG wrote: 31 May 2022, 17:59
Yes you can but still get clutch sensor fault
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
So I have found the plug now to get a sensor
Gwe89
Pro
Re: PBM RetroFit
Post by Gwe89 »
Still trying to get to the bottom of a fault code I have after fitting pbm U3000:00-2F can anyone help please?
Post Reply
