How to turn on the video on FX Plus
hanssi
Starter
Post by hanssi »
Hello everyone,
I have one FX Plus from Focus on the bench. I want to turn on the video input but no luck.
The CAN message for ignition is the same like on Mondeo - it works but if I send the message for the reverse gear - nothing.
Can anyone tell me if the CAN message is the same as the mondeo? Or another? Or does Radio in Focus use a different way to activate video input?
Thanks a lot!
Re: How to turn on the video on FX Plus
I also own such a unit. It should work like you told. Put a videosignal into green Fakra, send IGN and REV on CAN and you should see an image.
hanssi
Starter
Post by hanssi »
Okay, thanks for the info. I try to put it in the car if it works.
Please report. I will search my device and try to activate video the way i described.
hanssi
Starter
Post by hanssi »
So in the car (Mondeo FL) it work well, I see the picture from camera. But on the bench, my problem is probably that I have used the "UC*DS can bus player" for that. There is no possibility to set delay for each message.
Btw is there a way to hacking can bus with ELM327/ELS27 adapter for example with software like is Canhacker etc? Or I must have only Arduino, Lawicel etc?
hanssi
Starter
Post by hanssi »
So now also on the bench work fine :) The problem was that UC*DS can bus player has default speed on mm-can 500 Kbps - there is no settings. Now I have connected my FX to ms-can 125 Kbps and I have the picture from the camera :shock: after 3 days :? :D
Congrats! But why should UCDS use 500kbit/s on MM? Makes no sense to me...
In theory, ELM327 could be used to send CAN messages. I use a special, Lawicel compatible adaptor for this job.
hanssi
Starter
Post by hanssi »
My think - because Focus III, Fiesta from 2012 has 500 kbit/s on MM. I have one "display with Navi SD-card" MFD 5 from these cars on the bench and it work on 500 kbit/s.
BTW I'm looking for some CAN IDs for this MFD5. I want awake it 😊 if someone has, please post here.
Thanks.
