Using NX in preFL with C7ST-14D212 bluetooth-module
Hey guys, somebody asked me if this comibination work and i though yes. But after fitting he can use handsfree and speech-control, but does not see BT-audio buttons on NX. Strange, eh? Any ideas why? CCC is correct, Loop-plug is correct. He can bind his smartphone to the module and use phone, even on Convers+, but not BT audio.
sanndo
Re: Using NX in preFL with C7ST-14D212 bluetooth-module
Post by sanndo »
I have same problem with FX and after update fx to 4.1 bluetooth audio working fine. Did you try to update nx to 5.3 firm?
Sorry, forgott to mention that NX already is at SP 5.3
DGAlexandru
Post by DGAlexandru »
What editor do you use for CCC?
UC DS is not good - it misses some config options for BT ;)
I use good old ELMConfig or ForScan - "USB with streaming for Nav only" or something like this.
sanndo
Post by sanndo »
DGAlexandru is right. Did you check config with another soft? Or did you reset module?
ELMConfig is used for programming, Reset has been made.
I've found it with hint from a friend! It was just a silly mistake in my documentation, where i wrote to set "BT/VC High + USB + BTAudio + Nav" for NX/MCA and BT-Module with audio streaming. But that was wrong and instead it should be "BT/VC High + USB, and BTAudio for Nav only" ;)
amplified
Post by amplified »
All working now then?
Yes, it‘s working.
DGAlexandru
I said the same thing "for nav only"
