IPC Software
Re: IPC Software
Have you tried real before the facelift? I suspect it's the same version as between facelift and can't work ... "AM2T"
Re: IPC Software
This is how the additional functions compile into convers+, try to look at it ...
pass:
Conva
pass:
Conva
Re: IPC Software
The ddm is a 50/50 chance of working lucky I have ucds to recover dead module
Stops loading at 447 every time
ronald0001
- Active member
Re: IPC Software
is the conversmod needed with lightpack needed rigth now or you have it rigth now....
cuz i want to buy this addon for my convers...and when my es27 arrives from china i want to give you a dump...if wanted
ich have a vFL...2008
Re: IPC Software
ronald0001 wrote: ↑29 Dec 2019, 14:15 is the conversmod needed with lightpack needed rigth now or you have it rigth now....
If you are able to provide such dump, we will be honored
Tourist
Re: IPC Software
the chances of success are smaller
many times colleagues had to buy modules because they broke themselves
better future with childrens
Re: IPC Software
maybe it's late and everybody has own modification already, i'm just learning so much to move my old software, this is FL in preFL, czech language, lightmod, park.modus, digi speed etc. Maybe it will be helpfull for someone;) (btw it miss boost gauge, dpf indicator and colored themes)
never give up !
Re: IPC Software
here is your dump - recalculated - so if you wish you can load it back via IPCupdate- pass for zip on PMphx- wrote: ↑31 Dec 2019, 22:36 maybe it's late and everybody has own modification already, i'm just learning so much to move my old software, this is FL in preFL, czech language, lightmod, park.modus, digi speed etc. Maybe it will be helpfull for someone;) (btw it miss boost gauge, dpf indicator and colored themes)
Tourist
Re: IPC Software
Thank you, i have already loaded it in my c+, an member help me so much with it, now i trying make language in other c+ soft, mFl and preFL, but it so hard for me as newbie, so i reading every post "how to" make it easier,because i have no good tools like cable (just elm327) and only mine car predfl with fl converspaxtonix wrote: ↑02 Jan 2020, 10:05here is your dump - recalculated - so if you wish you can load it back via IPCupdate- pass for zip on PMphx- wrote: ↑31 Dec 2019, 22:36 maybe it's late and everybody has own modification already, i'm just learning so much to move my old software, this is FL in preFL, czech language, lightmod, park.modus, digi speed etc. Maybe it will be helpfull for someone;) (btw it miss boost gauge, dpf indicator and colored themes)
never give up !
Re: IPC Software
Did the 15xx firmware ever get released in China? wondering if that could be used to create the latest FW with all the mods and updated ESC lights etc
