IPC Software
paxtonix
IPC Software
Post by paxtonix »
Hi All,
Ok team :D
I have successfuly extracted the software form U*C*D*S* - So all versions of IPC update through this platform are available here.
All software is " hacked" so there is no need to insert VIN in BCM in order for aditional functions like PTC/BAT/Temp/DS/Popup to work.
CRC and Header -Recalculated.
Enjoy !
Archive contains :
Code: Select all
1122-preFL - IPC C+ part# 7M2T-10849, 8M2T-10849, 8U2T-10849 (to 15-03-2010)
1122-mFL - IPC C+ part# AM2T-10849 (15-03-2010 to 06-09-2010)
1412-FL - IPC C+ part# BS7T-10849, CS7T-10849 (6-09-2010 to 21-03-2014)
1412-FL_IPC_in_preFL - IPC C+ part# BS7T-10849, CS7T-10849 (6-09-2010 to 21-03-2014) installed in preFL car (to 15-03-2010)
7M2T-14C025-AA.vbf - SBL file
@Bezdomni Team Poland
Password Protected - PM me for That
Still looking for aditional versions of software. Some of them have ACC fix, some other have Belt reminder and AIRBAG fix. Also looking for software with boost gauge , and lamps textures for vFL an FL. So if Somebody have any software please dump it in this topic, so I can take a look and share for all of us.
@Ursadon - You are A Software Genius - Got my support.
Tourist
paxtonix
Re: IPC Software
Post by paxtonix »
Any one have this soft with light textures ? and or aditional boost gauge and DPF indicator ?
Tourist
DGAlexandru
Re: IPC Software
Post by DGAlexandru »
We have a user here on this forum that has "Boost" mode activated. I hope he will upload his dumps.
Thank you for your contribution. I was working on doing the same, but from dumps. I wasn't able to "decode" UC DS software in order to have this dumps saved.
Were you able to also dump the interface firmware? I have several UC DS interfaces that are missing their firmware - tests to see how I can add some credits for the Clone version. I also have a friend with an original one and we saved all the credits he bought, so if we manage to clone an original one over and over then we can reuse the credits ;)
Gwe89
Re: IPC Software
Post by Gwe89 »
do you know how to bypass the vin in the firmware?
DGAlexandru
Re: IPC Software
It is already patched. All the VBF files in that attachment have "VIN check routine" disabled and even removed from the Firmware.
I was very close to do find them also :P
vodafone
Re: IPC Software
Post by vodafone »
had this problem with ACC
But yesterday a UK guy did this to me :)
I think nobody does it except him.
better future with childrens
Artist
Re: IPC Software
Post by Artist »
Dump file before and after...
ronald0001
Re: IPC Software
Post by ronald0001 »
ic an flash this files olso with the ipc updater from Ursadon and elm327?
or i need UCDS?
i have a vFL C+ with basic Conversmod
so i do first a dump or can i download my old conversmod all time?
paxtonix
Re: IPC Software
Post by paxtonix »
ronald0001 wrote: 20 Nov 2019, 13:42
Download the old one and, post the dump here. I will take a look what you have , and fit all of it in one firmware. At least I will try🤣
Tourist
ronald0001
Re: IPC Software
paxtonix wrote: 20 Nov 2019, 14:23
i must look in the modinstaller maybe vbf file is saved there also
no it isnt....
so i must wait about 3h to charge my Tablet/Notebook....battery is tatal empty
