IPC Software
Artist
Active member
Re: IPC Software
Post by Artist »
Have you tried real before the facelift? I suspect it's the same version as between facelift and can't work ... "AM2T"
Artist
Active member
Re: IPC Software
Post by Artist »
This is how the additional functions compile into convers+, try to look at it ...
pass:
Conva
Gwe89
Pro
Re: IPC Software
Post by Gwe89 »
The ddm is a 50/50 chance of working lucky I have ucds to recover dead module
Stops loading at 447 every time
ronald0001
Active member
Re: IPC Software
Post by ronald0001 »
is the conversmod needed with lightpack needed rigth now or you have it rigth now....
cuz i want to buy this addon for my convers...and when my es27 arrives from china i want to give you a dump...if wanted
ich have a vFL...2008
paxtonix
Active member
Re: IPC Software
Post by paxtonix »
ronald0001 wrote: 29 Dec 2019, 14:15 is the conversmod needed with lightpack needed rigth now or you have it rigth now....
If you are able to provide such dump, we will be honored ;)
Tourist
vodafone
Re: IPC Software
Post by vodafone »
Gwe89 wrote: 14 Dec 2019, 12:46 The ddm is a 50/50 chance of working lucky I have ucds to recover dead module
the chances of success are smaller
many times colleagues had to buy modules because they broke themselves
better future with childrens
phx-
Starter
Re: IPC Software
Post by phx- »
maybe it's late and everybody has own modification already, i'm just learning so much to move my old software, this is FL in preFL, czech language, lightmod, park.modus, digi speed etc. Maybe it will be helpfull for someone;) (btw it miss boost gauge, dpf indicator and colored themes)
never give up !
paxtonix
Active member
Re: IPC Software
Post by paxtonix »
phx- wrote: 31 Dec 2019, 22:36 maybe it's late and everybody has own modification already, i'm just learning so much to move my old software, this is FL in preFL, czech language, lightmod, park.modus, digi speed etc. Maybe it will be helpfull for someone;) (btw it miss boost gauge, dpf indicator and colored themes)
here is your dump - recalculated - so if you wish you can load it back via IPCupdate- pass for zip on PM
Tourist
phx-
Starter
Re: IPC Software
Post by phx- »
paxtonix wrote: 02 Jan 2020, 10:05
Thank you, i have already loaded it in my c+, an member help me so much with it, now i trying make language in other c+ soft, mFl and preFL, but it so hard for me as newbie, so i reading every post "how to" make it easier,because i have no good tools like cable (just elm327) and only mine car predfl with fl convers
never give up !
bigi
Starter
Re: IPC Software
Post by bigi »
Did the 15xx firmware ever get released in China? wondering if that could be used to create the latest FW with all the mods and updated ESC lights etc
Post Reply
