Also another one I have pulled from an old mod and put into one of my own files Same again same bytes at 145B5,6,7,8 in main, logo inserted at same address in flash from old mod to new
What i work on is a webservice where one can upload an arbitrary image and get a VBF in return. Then he needs an uploader where i think of an EXE written in C++ and using plain ELM. OMG, wait! this would break somebodys business...
What's your problem in people making money on CM, I dont charge much the customer is getting what they want, installed by someone who knows what they are doing. Invested in the tools to do things properly, and most importantly time my time
What's not correct, source code is available so could be fixed to work then we all have a decent encoder
Just tested after adding a logo it finds it but the background should be black not the pink colour
But this one fine
Gey gwe89, why are your pictures all turned by 90 degree?
- Pro
We have it: it's IPC Updater! As long as you have a valid VBF, it's all you need.
I keep see this "ConversHacker" images/logos application for windows. Is this from Ursadon or someone else? Do we have a download link for it?
like this but takes about 1 hour to install sometimes longer if pc spec aint so good
Found another logo and added it to preface firmware always different bytes at the location I found so definatly found the bytes in main that tell it where the logo is
