Gwe89
Pro
Post by Gwe89 »
Also another one I have pulled from an old mod and put into one of my own files Same again same bytes at 145B5,6,7,8 in main, logo inserted at same address in flash from old mod to new
Pro
Post by Go4IT »
What i work on is a webservice where one can upload an arbitrary image and get a VBF in return. Then he needs an uploader where i think of an EXE written in C++ and using plain ELM. OMG, wait! this would break somebodys business... :o :lol:
Gwe89
Pro
Post by Gwe89 »
Go4IT wrote: 21 Dec 2019, 07:56 What i work on is a webservice where one can upload an arbitrary image and get a VBF in return. Then he needs an uploader where i think of an EXE written in C++ and using plain ELM. OMG, wait! this would break somebodys business... :o :lol:
What's your problem in people making money on CM, I dont charge much the customer is getting what they want, installed by someone who knows what they are doing. Invested in the tools to do things properly, and most importantly time my time
Gwe89
Pro
Post by Gwe89 »
tasicky wrote: 19 Dec 2019, 21:40 The encoding algorithm in this program is not entirely correct.
What's not correct, source code is available so could be fixed to work then we all have a decent encoder
Just tested after adding a logo it finds it but the background should be black not the pink colour
Gwe89
Pro
Post by Gwe89 »
But this one fine
Pro
Post by Go4IT »
Gey gwe89, why are your pictures all turned by 90 degree? ;)
Gwe89
Pro
Post by Gwe89 »
Go4IT wrote: 21 Dec 2019, 16:13 Gey gwe89, why are your pictures all turned by 90 degree? ;)
I dont know but when you press on the image it's the right way up I did think that my self maybe it's the way my phone takes photos
DGAlexandru
Pro
Post by DGAlexandru »
Go4IT wrote: 21 Dec 2019, 07:56 Then he needs an uploader where i think of an EXE written in C++ and using plain ELM.
We have it: it's IPC Updater! As long as you have a valid VBF, it's all you need.
I keep see this "ConversHacker" images/logos application for windows. Is this from Ursadon or someone else? Do we have a download link for it? :roll:
Gwe89
Pro
Post by Gwe89 »
like this but takes about 1 hour to install sometimes longer if pc spec aint so good
Gwe89
Pro
Post by Gwe89 »
Found another logo and added it to preface firmware always different bytes at the location I found so definatly found the bytes in main that tell it where the logo is
Post Reply
