Post Reply
marekrbk
Active member
vbf tool editor
Post by marekrbk »
editor
Gwe89
Pro
Post by Gwe89 »
Are the logos in the exe or the data
DGAlexandru
Pro
Post by DGAlexandru »
Data - External Flash - 2MB file.
drobec.eu
Starter
Post by drobec.eu »
Ursadon wrote: 22 Mar 2019, 17:14 Grab my soft at https://github.com/Ursadon/ConversHacker
Not found in github :cry:
Can provide it again on github? or PM?
Thanks.
Pro
Post by Go4IT »
It is a private project from Ursadon, not public. Ask him to give you a EXE or access to the code if you could contribute (C++).
marekrbk
Active member
Post by marekrbk »
make my photo to custom thanks
tomy75
Active member
Post by tomy75 »
vodafone
Post by vodafone »
look
better future with childrens
drobec.eu
Starter
Post by drobec.eu »
to change the logo it is necessary to register the new image to firmware convers.
help someone how to do it?
Thanks
paxtonix
Active member
Post by paxtonix »
drobec.eu wrote: 07 Dec 2019, 21:32 to change the logo it is necessary to register the new image to firmware convers.
Thanks
You need to add a new address to bootloader in main. If you insert new logo in the place of the old one , it will not show up on dash. Seems the block lenght don't fit. You can fit it in other place of flash, and just add, a string to the address you have your logo. I'll share my conclusion later.
Tourist
Post Reply
