Update IPC
User avatar
Stevebe
Pro
Re: Update IPC
Post by Stevebe »
tomy75 wrote: ↑28 Nov 2019, 11:33 I have elm327 500k usb interface
I have had this happen when I have been updating ipc on the bench and when connected to the MSCAN and at the same time reading MM CAN
Just stop the MM CAN FROM reading at same time....
Digimod
tomy75
Active member
Re: Update IPC
Post by tomy75 »
How should I do that?what stop mmcan bus?
User avatar
Stevebe
Pro
Re: Update IPC
Post by Stevebe »
tomy75 wrote: ↑29 Nov 2019, 05:19 How should I do that?what stop mmcan bus?
are you running the IPC updater od the bench or is the IPC in your Car
Digimod
tomy75
Active member
Re: Update IPC
Post by tomy75 »
IPC its in my car
User avatar
Stevebe
Pro
Re: Update IPC
Post by Stevebe »
tomy75 wrote: ↑29 Nov 2019, 22:32IPC its in my car
Make certain every thing is of, only put key to on for convers to come on. Then just try doing a eeprom dump..
if that works ok you should be ok.. as I said only causes we have come across this is when the can bus is extremely busy.
Regards
Digimod
tomy75
Active member
Re: Update IPC
Post by tomy75 »
Eeprom dump no working
User avatar
Stevebe
Pro
Re: Update IPC
Post by Stevebe »
tomy75 wrote: ↑30 Nov 2019, 07:21 Eeprom dump no working
What are you seeing when you try a Eeprom dump ?
Digimod
tomy75
Active member
Re: Update IPC
Post by tomy75 »
When i start eeprom dump See this
download/file.php?id=511&mode=view
User avatar
Stevebe
Pro
Re: Update IPC
Post by Stevebe »
tomy75 wrote: ↑30 Nov 2019, 21:18 When i start eeprom dump See this
Unselect the main and the extended files. The bottom to leave the bootloader then try eeprom dump
Digimod
Pro
Re: Update IPC
Post by Go4IT »
You need an ELS327 cable, it won't work with a ELM327.
Post Reply
