Ok team
I have successfuly extracted the software form U*C*D*S* - So all versions of IPC update through this platform are available here.
All software is " hacked" so there is no need to insert VIN in BCM in order for aditional functions like PTC/BAT/Temp/DS/Popup to work.
CRC and Header -Recalculated.
Enjoy !
Archive contains :
Code: Select all
1122-preFL - IPC C+ part# 7M2T-10849, 8M2T-10849, 8U2T-10849 (to 15-03-2010)
1122-mFL - IPC C+ part# AM2T-10849 (15-03-2010 to 06-09-2010)
1412-FL - IPC C+ part# BS7T-10849, CS7T-10849 (6-09-2010 to 21-03-2014)
1412-FL_IPC_in_preFL - IPC C+ part# BS7T-10849, CS7T-10849 (6-09-2010 to 21-03-2014) installed in preFL car (to 15-03-2010)
7M2T-14C025-AA.vbf - SBL file
@Bezdomni Team Poland
Still looking for aditional versions of software. Some of them have ACC fix, some other have Belt reminder and AIRBAG fix. Also looking for software with boost gauge , and lamps textures for vFL an FL. So if Somebody have any software please dump it in this topic, so I can take a look and share for all of us.
@Ursadon - You are A Software Genius - Got my support.
