Trailer module
Gwe89
Pro
Trailer module
Post by Gwe89 »
Hi I have bought a volvo module in the hope to try and see if it will work as the ford ones are expensive, I can poll the module ect in UCDS, when I change my BCM configuration with trailer module I get error on trailer module software incompatible, and it stops my parking sensors working,
Now is there a way to read this chip? I wonder if it could be read with jtag
There is a port on the board also
DGAlexandru
Pro
Re: Trailer module
Post by DGAlexandru »
Looks the same as the Ford one.
Try to put the Ford software on it - by OBD - normal vbf flash or by flashing that Motorola (Freescale) 9S12D64 chip, using that "port" you have in the last photo (GND, Reset, VCC, BKGD) - but for this last procedure you need a dump.
Gwe89
Pro
Re: Trailer module
Post by Gwe89 »
DGAlexandru wrote: ↑24 Aug 2022, 04:29 Looks the same as the Ford one.
I tried with ucds also with dead module programing but I get SEED error, what device do I need to program this chip, I have jtag but I'm not 100% with it as its new to me
DGAlexandru
Pro
Re: Trailer module
JTAG is totally different from "BDM"
There are lots of tools that work with Motorola 9S12, especially D64 version which is very old... but for this to work you need a Dump from a Ford module.
If UCDS has the needed files, then try to use ForScan to update it by OBD ... or Ford IDS.
Gwe89
Pro
Re: Trailer module
Post by Gwe89 »
DGAlexandru wrote: ↑25 Aug 2022, 04:58 JTAG is totally different from "BDM"
I dont think ForScan has an option to update trailer module, I have the sbl ect and 2 other files one I think is flash and other is possibly eeprom
DGAlexandru
Pro
Re: Trailer module
You could try to understand where those VBFs fit into Flash Memory and write their contents over BDM.
Saving first the entire Flash from 9S12D64 by BDM you can do an "unlimited" number of tryouts to convert it to a Ford one.
Gwe89
Pro
Re: Trailer module
Post by Gwe89 »
DGAlexandru wrote: ↑25 Aug 2022, 19:55 You could try to understand where those VBFs fit into Flash Memory and write their contents over BDM.
Is there any cheap tools that could read and write to this module
Gwe89
Pro
Re: Trailer module
Post by Gwe89 »
Could you please tell me the pin out on this port please
DGAlexandru
Pro
Re: Trailer module
For the pinout - just use a multimeter and PDF of 9S12D64 to discover the 3 or 4 (depending if you use power from Programmer to power the board) pins needed.
Post Reply
