Mondeo MK5 IPC
amplified
Active member
Re: Mondeo MK5 IPC
Post by amplified »
You need to send it all the time, no just one time msg
Solltex
Starter
Re: Mondeo MK5 IPC
Post by Solltex »
Yes, I send with UCDS two can id, all good, but how close CanBusPlayer windows and go to vbf loader, IPC off :)
Need other can sender like andruino or ....?
On mk4 I made from BCM, here is different
sanndo
Active member
Re: Mondeo MK5 IPC
Post by sanndo »
Solltex wrote: 22 Nov 2021, 17:22 Need other can sender like andruino or ....?
Arduino + CanHacker work great
Solltex
Starter
Re: Mondeo MK5 IPC
Post by Solltex »
Why need arduino, only one CanHacker can send can id, or no?
amplified
Active member
Re: Mondeo MK5 IPC
Post by amplified »
Well, how you expect to send ignition msg from ucds and then go to vbf and send another msg simultaneously :D :D
You need one device to send, another to flash.
sanndo
Active member
Re: Mondeo MK5 IPC
Post by sanndo »
Check this threat:
viewtopic.php?t=168
Solltex
Starter
Re: Mondeo MK5 IPC
Post by Solltex »
amplified wrote: 23 Nov 2021, 10:45 Well, how you expect to send ignition msg from ucds and then go to vbf and send another msg simultaneously :D :D
on mk4 ipc you can separately send id, close, and go to vbf uploader ;)
Solltex
Starter
Re: Mondeo MK5 IPC
Post by Solltex »
sanndo wrote: 23 Nov 2021, 11:04 Check this threat:
viewtopic.php?t=168
nice, I buy today and waiting delivery ;) thanks
Solltex
Starter
Re: Mondeo MK5 IPC
Post by Solltex »
How off left menu (Fuel level low) :roll:
Post Reply
