Mondeo MK5 IPC
Re: Mondeo MK5 IPC
You need to send it all the time, no just one time msg
Re: Mondeo MK5 IPC
Yes, I send with UCDS two can id, all good, but how close CanBusPlayer windows and go to vbf loader, IPC off
Need other can sender like andruino or ....?
On mk4 I made from BCM, here is different
Re: Mondeo MK5 IPC
Why need arduino, only one CanHacker can send can id, or no?
Re: Mondeo MK5 IPC
Well, how you expect to send ignition msg from ucds and then go to vbf and send another msg simultaneously
You need one device to send, another to flash.
Re: Mondeo MK5 IPC
Check this threat:
viewtopic.php?t=168
viewtopic.php?t=168
Re: Mondeo MK5 IPC
on mk4 ipc you can separately send id, close, and go to vbf uploader
Re: Mondeo MK5 IPC
nice, I buy today and waiting delivery thanks
Re: Mondeo MK5 IPC
How off left menu (Fuel level low)
