pdm ddm ubdate fault code
Re: pdm ddm ubdate fault code
Cool, what calibration files you added?
return the original calibration,error u0300 removed.
And working folding rearview mirrors?
folding rearview mirrors the function expires. if you want the function again, update only DDM
Tested other module in my mondeo and works great . My mondeo for facelift. Testet module after facelift.
with fl module in front you loose one touch up rear windows.
you did not read carefully - with fl modules in front only - then you loose one touch in rears. if you replace all 4 - its working. when forscan can update and just one U error... i see no point in purchasing 4 modules, because of just one DTC.
I don't want any errors, so I want all the features without any problems.
