pdm ddm ubdate fault code
amplified
Active member
Re: pdm ddm ubdate fault code
Post by amplified »
Cool, what calibration files you added?
marekrbk
Active member
Post by marekrbk »
return the original calibration,error u0300 removed.
tomy75
Active member
Post by tomy75 »
And working folding rearview mirrors?
marekrbk
Active member
Post by marekrbk »
folding rearview mirrors the function expires. if you want the function again, update only DDM
marekrbk
Active member
Post by marekrbk »
Tested other module in my mondeo and works great . My mondeo for facelift. Testet module after facelift.
amplified
Active member
Post by amplified »
with fl module in front you loose one touch up rear windows.
marekrbk
Active member
Post by marekrbk »
amplified wrote: ↑15 Apr 2020, 11:03 with fl module in front you loose one touch up rear windows.
nonsense,all works fine
marekrbk
Active member
Post by marekrbk »
amplified
Active member
Post by amplified »
you did not read carefully - with fl modules in front only - then you loose one touch in rears. if you replace all 4 - its working. when forscan can update and just one U error... i see no point in purchasing 4 modules, because of just one DTC.
marekrbk
Active member
Post by marekrbk »
I don't want any errors, so I want all the features without any problems.
Post Reply
