Transmitting infodata on MM-CAN
- Active member
Re: Transmitting infodata on MM-CAN
please can someone do a short log of mm-can while is playing music via bt-audio?
4D0 # 62 00 00 00 = satnav connected to canbus (means you can see radio and auxilary in in the c+ but not selectable)
2E3 # 00 = radio/satnav off
2e3 # 0A = radio/satnav on
4DB # 15 05 00 00 00 00 00 00 = shows navigation in the list of c+
4De # 22 00 00 00 00 00 00 00 = shows telefon in the list of c+ (not selectable cuz not connected)
go4it give me some traces but two of them shows me like he was calling...and the other one there he play form usb not bluetooth...so it shows me a list of songs wich i can select with up and down
4DC # 78 08 00 00 00 00 00 00 = shows USB - AUX in c+ but needs also any other id to be activated
- Active member
Re: MCA reverse video
Go4IT wrote: ↑17 Jan 2020, 22:28 What i found in my research is that MP3 played from USB (FL Mondeo with S&C) gives titles on ID 4C7 (MM-CAN),
Phone via Bluetooth uses 4C3, 4C6
Radiotext and Navigationtargets comes via 4C1 (MSB is multiplex-index)
Also 4B0 (Bluetooth Musik, multiplex)
4B2+4B3 Station names
on usb playing it gives you alist of the mp3 stored on the usbmemory
4c1 radiotext is i think couze you habe dab+??????
4b2 and 4b3 also cuz of dab+???
or function of mca direkt???
i will try 4B0 with the cantrace you send me...cuz your trace is only active bt audio but not showing any trackinfos...seems no song was played while you make the trace...only connect phone and set aux to bt...
Just a short video of data captured and programmed on MM and MS can
The streamed back on 2 streamed channels and 2 loop channels
https://youtu.be/pWqQy04J2E4
Digimod
- Active member
oh my god
you need a bigger screen...maybe 65"....
steveb
you have a cabdump while bt audio plays a song and send text/trackinfos to the convers on mmcab
steveb
I’ll try and get it done this week but my motor is in for service Monday as soon as I get it back I’ll log the ms and Mm busronald0001 wrote: ↑26 Jan 2020, 23:58 oh my god![]()
steveb
Wile Streaming BT as you requested. But I have to say I can’t recall seeing any C+ Misic Text wile on BT only the BT icon
But will find out for you
Digimod
- Active member
ah ok...some pepble told me if the play a song lile from youtube they see information about title in c+....
doesnt matter i can use also the radio stationnames id
I’ll test to make certain I’ll still record can data for youronald0001 wrote: ↑27 Jan 2020, 00:32 ah ok...some pepble told me if the play a song lile from youtube they see information about title in c+....
Digimod
- Pro
Yes, Stevebe is wright - you don't get text on C+ while you have audio over BT, only MP3 over USB or MP3 in CD.
- Active member
but then it sends you a list of titels into the convers...not only the played one with mediainfoDGAlexandru wrote: ↑27 Jan 2020, 07:31 Yes, Stevebe is wright - you don't get text on C+ while you have audio over BT, only MP3 over USB or MP3 in CD.
the fx can play mp3 via cd?
so i will stay on radio to show mediainfo in c+
its not so nice cuz only have one line and 8signs to show...
would be nice to have two or 3 lines...but it seems not to be possible...
maybe anyone can do a funktion for this ...hahaha
- Pro
If you emulate MP3 (CD or USB) mode on your RaspBerry PI then you will have more than one line:
one for track name
one for album name
one for artist name
... if I remember correctly.
FX knows CD-MP3, SD-MP3 and USB MP3 (on a BT with enabled USB).
NX and Sony know CD-MP3 and USB MP3 (on a BT with enabled USB).
one for track name
one for album name
one for artist name
