Transmitting infodata on MM-CAN
oscarboiro
Post by oscarboiro »
In my first experiments with can bus, I send message to instrument cluster of my kuga mk1, I replace the radio info and the street name in the nav mode, and this is the result.
The text are ascii in hex, I use the windows programmers calc to convert ascii code to hex.
Kuga MK1 owner
Re: MCA reverse video
What i found in my research is that MP3 played from USB (FL Mondeo with S&C) gives titles on ID 4C7 (MM-CAN),
Phone via Bluetooth uses 4C3, 4C6
Radiotext and Navigationtargets comes via 4C1 (MSB is multiplex-index)
Also 4B0 (Bluetooth Musik, multiplex)
4B2+4B3 Station names
ronald0001
Post by ronald0001 »
Travelpilot send Station Name on id id 1E9...
so its maybe different for every radio/satnav
https://www.youtube.com/watch?v=AseLG_cKs4c
That could absolutely be true. I did not investigate this further, even if i got all kinds of satnav systems here at hand, but too less time, you know :?
These are only my findings with an MCA.
It would be good if we could share CAN IDs and meanings on behalf of functionality...
User avatar
Stevebe
Post by Stevebe »
Go4IT wrote: 19 Jan 2020, 00:44 That could absolutely be true. I did not investigate this further, even if i got all kinds of satnav systems here at hand, but too less time, you know :?
Need to make up a Xl spreed sheet or somat. There is so much great data
Digimod
ronald0001
ronald0001 wrote: 18 Jan 2020, 01:23 Travelpilot send Station Name on id id 1E9...
also fx send audio source to convers via id 1E6
ronald0001
fx id 1e9 radio station name
Re: Transmitting infodata on MM-CAN
NOTE: I've separated the topic as it now is too different from the original one.keep on going, this is intersting stuff :D
ronald0001
Go4IT wrote: 17 Jan 2020, 22:28 Radiotext and Navigationtargets comes via 4C1 (MSB is multiplex-index)
fx also send navigationtargets via 4c1
radiotext maybe only when you have a mca with dab?
ronald0001
i look for message on 1e6 when is usb source and bt audio source is active....i dont have s&c
and wich id and message is for telling the convers that radio/satnav is on?....
the front/buttonpanel of my experimental fx is not working anymore....
i can but on but i cant insert pin :shock: :lol: :lol:
