Convers mod boost gauge
Gwe89
Post by Gwe89 »
Been doing some logging and found the ID for the boost gauge
paxtonix
Re: Convers mod boost gauge
Post by paxtonix »
:shock: Nice.
This boost gauge is implemented in your ipc soft?
Tourist
Gwe89
Post by Gwe89 »
Yes I have conversmod full mod
paxtonix
Post by paxtonix »
Nice.
I saw how much they claim for it. Would be nice to make some tests on it but 300euro for full c+ mod throw me off.
Still looking where vin number is located in ipc.
DGAlexandru
Post by DGAlexandru »
Very Nice.
Where is the Main Dump? :D
I'm also working on finding out where is the VIN checking mechanism and a way to bypass it... just need more time :)
What I don't like with the way they did it is that for PreFL the AirBag LED is not working as it should - it doesn't light when there is an AirBag problem; you have configuration errors on IPC and I'm missing the "turn off audio only on driver door open" as it is on FaceLift... so I started to dissasemble with IDA the modifications they have done to figure it out.
Another thing which I don't like is that on FaceLift they don't release mods with the latest FW version from Ford.
BTW, working on FL FW it's much easier, as there are less modifications done for the "basic" UC DS Mot Ral FirmWare.
bigi
Starter
Post by bigi »
It is quite frustrating that the FL FW is not the last release - the reason this wasn't done was because "there was not enough value" in it (to quote motral when i asked). It is quite frustrating - especially with a last release convers because it means that the EML light shows up as "ESC Off" due to the change in code when the conversmod is installed :shock:
Gwe89
Post by Gwe89 »
DGAlexandru wrote: 17 Nov 2019, 16:23 Very Nice.
i have already found the bypass for the vin and hacked my own mod and as an ex convermod patner i have full mod in pre, middle, middle compability, fl and fl compability and they all have the videoin option for the mca navigation units with rear camera me and a freind have already cracked the videoin adapter, but need to work on the boost and dpf regen indicator i have all the canbus codes needed just need to be able to read this from HS-CAN and pass it to MS-CAN
i also have full mod with tpms for pre and FL
full mod= dpf regen, boost guage, light pack, aditional guages, videoin, themes for FL, parking display, digital speed
DGAlexandru
If you have them, please share with us.
If you know the CAN messages then it is easy to build a gateway adapter from HS-CAN to MS-CAN. (normally this is done by BCMII, this one should have forward the DPF status for example).
paxtonix
Post by paxtonix »
Gwe89 wrote: 19 Nov 2019, 22:13
I can help you with that. Will you share the software in exchange ?
Tourist
tasicky
Starter
Post by tasicky »
Gwe89 not found bypass routine. They found differential between software shared by Paxtronix and protected org version and used it :D
