Caravan motor mover
Gwe89
Caravan motor mover
Post by Gwe89 »
A bit off topic
@GO4IT, maybe the best to help here, I have a motor mover on my caravan and the controller's faulty, I belive its not putting out a good signal, controller has to literally be next to the control box
Here's a few pictures, how would I test the components to replace them,
Is there anything you can see that could be a likley faulty part
Here circled I belive to be the antenna, when the antenna wire from the control box is close to this area it works perfectly
