Sleep mode
Syntax
Sleep mode
Post by Syntax »
Is there some timeout when the car enters sleep mode after IT is locked and stops any communication on MS CAN?
I have been logging 048 msg for about two hours and the car still kept sending it (with ignition byte 0x20).
Re: Sleep mode
It should go to deep sleep in several steps. After about 30 mins most should be off.
Syntax
Re: Sleep mode
Post by Syntax »
Then there is something wrong in my car that is preventing from going to sleep.
