Sync 3 canbus
amplified
Sync 3 canbus
Post by amplified »
I have here one supposed dead sync3 module
Anybody have ignition on can message so i can bench test it?
Also i am searching for plug pinout for the unit.
Car is in absolutely bad shape and cant test on it before i fix the wiring harness which is absolutely deatroyed.
amplified
Re: Sync 3 canbus
Post by amplified »
I found out what i was looking for
Pin 1 vcc
Pin 37 ground
Pin 19 can high
Pin 20 can low
