Page 1 of 2
Looking for alternative RAM-Chips for Travelpilot devices
Posted: 28 Dec 2020, 14:50
by sanndo
Little off, but..
Can we replace RAM chips with other parts numbers? Not only 46V64M8P?
Re: Hey guys
Posted: 19 Jan 2021, 20:52
by cipicas
sanno, regarding 46v64m8 chips, yes I found others that work.
tested at -18C
Re: Hey guys
Posted: 19 Jan 2021, 22:38
by sanndo
cipicas wrote: ↑19 Jan 2021, 20:52
tested at -18C
Cool! Haha
What chip can I use to replace dead 46v64m8?
Re: Hey guys
Posted: 21 Jan 2021, 15:17
by cipicas
sanndo
I use KDLD88P4PAG-53X. Can be found on ddr kingmax 400 module. Last test was at -18C.
Also please use small tip for soldering not hot air.
cheers
Re: Looking for alternative RAM-Chips for Travelpilot devices
Posted: 27 Jan 2021, 09:26
by Go4IT
Note: i moved your question to a separate topic as it does not directly belong to the question you posted it into. But anyway, a good question as there are now genuine chips on the market anymore and China market only sells fakes or bad quality chips.
Re: Hey guys
Posted: 27 Jan 2021, 18:33
by Go4IT
cipicas wrote: ↑21 Jan 2021, 15:17
Hard to find in Germany. Also no datasheet of the chips to compare timings, etc. Need to select the chips, because of production tolerances some could stand the cold, some not. All consumer RAM chips are not for automotive temp range. Usually they fail unter -10 degree. But it's worth testing...
Posted: 29 Jan 2021, 12:42
by cipicas
Helo,
That's why I tested this chips at -18C and unit start ok. Also if the car is not started for more than 3 days it power nicely.
I had a datasheet(lost in transfer), compared and are perfect for swap.
cheers
Posted: 01 Feb 2021, 11:30
by sanndo
Did you know KDLD88P4EA-53 will work?
Posted: 01 Feb 2021, 12:56
by Go4IT
Unfortunately i could not find ANY datasheet for those kind of chips, so it's impossible to say if any variant is just a different production code or relevant specs.
Posted: 01 Feb 2021, 13:10
by Go4IT
From my various repairs i collected these "alternative RAM chips, which seems to work somehow:
Brand: Elixir
Chip: N2DS51280BS 5T
Used on: M2Y51264DS88B1G-5T (512MB, DDR-400MHz, CL3, PC3200U)
Datasheet:
NOT FOUND
Brand: KINGMAX
Chip: KDLD88P4PAG-53X
Used on: MPXC22F-D8KT4B (512MB, DDR-400) and MSA22F-D8KT3 (512MB, DDR-333)
Datasheet:
NOT FOUND
Brand: hynix
Chip: HY5DU12822BT-D43
Used on:
Datasheet:
hynix HY5DU12822BT-D43.pdf
Brand: Samsung
Chip: K4H510838C-UCCC or K4H510838J-LCCC
Used on:
Datasheet:
Samsung K4H510838D Datasheet.pdf
