Looking for alternative RAM-Chips for Travelpilot devices
sanndo
Post by sanndo »
Little off, but..
Can we replace RAM chips with other parts numbers? Not only 46V64M8P?
cipicas
Starter
Re: Hey guys
Post by cipicas »
sanno, regarding 46v64m8 chips, yes I found others that work.
tested at -18C :)
Ciprian
sanndo
Re: Hey guys
Post by sanndo »
cipicas wrote: 19 Jan 2021, 20:52 sanno, regarding 46v64m8 chips, yes I found others that work.
tested at -18C :)
Cool! Haha
What chip can I use to replace dead 46v64m8?
cipicas
Starter
Re: Hey guys
Post by cipicas »
sanndo
I use KDLD88P4PAG-53X. Can be found on ddr kingmax 400 module. Last test was at -18C.
Also please use small tip for soldering not hot air.
cheers
Ciprian
Re: Looking for alternative RAM-Chips for Travelpilot devices
Note: i moved your question to a separate topic as it does not directly belong to the question you posted it into. But anyway, a good question as there are now genuine chips on the market anymore and China market only sells fakes or bad quality chips.
Re: Hey guys
cipicas wrote: 21 Jan 2021, 15:17 I use KDLD88P4PAG-53X. Can be found on ddr kingmax 400 module. Last test was at -18C.
Hard to find in Germany. Also no datasheet of the chips to compare timings, etc. Need to select the chips, because of production tolerances some could stand the cold, some not. All consumer RAM chips are not for automotive temp range. Usually they fail unter -10 degree. But it's worth testing...
cipicas
Starter
Post by cipicas »
Helo,
That's why I tested this chips at -18C and unit start ok. Also if the car is not started for more than 3 days it power nicely.
I had a datasheet(lost in transfer), compared and are perfect for swap.
cheers
Ciprian
sanndo
Post by sanndo »
Did you know KDLD88P4EA-53 will work?
Unfortunately i could not find ANY datasheet for those kind of chips, so it's impossible to say if any variant is just a different production code or relevant specs.
From my various repairs i collected these "alternative RAM chips, which seems to work somehow:
Brand: Elixir
Chip: N2DS51280BS 5T
Used on: M2Y51264DS88B1G-5T (512MB, DDR-400MHz, CL3, PC3200U)
Datasheet: NOT FOUND
Brand: KINGMAX
Chip: KDLD88P4PAG-53X
Used on: MPXC22F-D8KT4B (512MB, DDR-400) and MSA22F-D8KT3 (512MB, DDR-333)
Brand: hynix
Chip: HY5DU12822BT-D43
Used on: ???
Datasheet:
hynix HY5DU12822BT-D43.pdf
Brand: Samsung
Chip: K4H510838C-UCCC or K4H510838J-LCCC
Used on:
Datasheet:
Samsung K4H510838D Datasheet.pdf
