Hi
Thomas1402
Hi
Hi @ all,
my name ist Thomas. I´m an engineer of automotive electronics from Zwickau/Germany. At work and as a hobby I design PCB, build and program them. Over the next months I´d like to create a gateway between Android head units and the Ford Convers+.
Re: Hi
Hi can you make pcb if we had the design for youThomas1402 wrote: ↑28 Oct 2020, 18:48 Hi @ all,
Re: Hi
I have a ardunio Leonardo canbus board but its only 1 chanel, could be redesigned to have 2 canbus channels then could do away with my nano and the 2 mcp2515
https://www.hobbytronics.co.uk/leonardo ... qvEALw_wcB
Re: Hi
Hi thanks for getting back to me, yes basically like the one iv posted here but with 2 can channels so would need both the can chips I think, the CS for this board is 17 and there's other pins available to use for CSThomas1402 wrote: ↑17 Nov 2020, 17:20Hi Gwe89,
unfortunately I can´t see your appendix yet. Do you need the design for two CAN channels with MCP2515?
Thomas1402
Re: Hi
I received your PN, but cause I´m new, I can´t answer it...
Go4IT is it possible to activate my profile?
Re: Hi
Send me email if you still can't reply to my messageThomas1402 wrote: ↑19 Nov 2020, 19:28I received your PN, but cause I´m new, I can´t answer it...Go4IT is it possible to activate my profile?![]()
gwe1989@gmail.com
