Page 1 of 1
Hi There
Posted: 06 Feb 2020, 06:05
by getsome
I´m a 41 year old electronics engineer that works with root cause analysis at one of the biggest electronic companies in my Sweden , I hope that my knowledge in electronics will help someone here , I have also been a huge fan of Ford cars since 1998.
Re: Hi There
Posted: 06 Feb 2020, 06:15
by Go4IT
Be very welcome to our small (but growing) community here! As i am also adicted to electronics (even i'm not an engineer) i guess we have some commons
Are there any special interests of yours? Any projects?
Re: Hi There
Posted: 06 Feb 2020, 06:31
by getsome
Hi.
The only project for the car is in idle right now , but I had plans to try to build some kind of a translator with elm327 and arduino to see the soot % and dpf % loadings on my IPC , or atleast to make a dpf symbol appear during a regen.
Other non relating project I built in the past is an Arduino controller for my wood burning Furnace to optimize the wood burning / gasification process in an optimal rate , this unit basically measured the exhaust temp by the means of a K Type thermocoupler , this information was then used to control primary and secondary air inlet valves with stepper motors so nothing really to do with cars
Re: Hi There
Posted: 06 Feb 2020, 06:55
by Go4IT
My passion are Ford navigation systems, especially the FX, NX and MCA. Did a lot with them, and publish a lot of information and repairs. I also run a wiki dedicated to Ford Mondeo. Besides electronics, microcontrollers and programming is another passion of mine.
Re: Hi There
Posted: 08 Feb 2020, 17:11
by ronald0001
hi...and i am the newbi here in tge forom...tey to learn...my project is a carpc wich finaly should replace the original satnv...in my kind the fx...inc can-bus
Re: Hi There
Posted: 14 Feb 2020, 09:15
by paxtonix
getsome wrote: ↑06 Feb 2020, 06:05
Might be I will need your help with Haldex controler in my Mondeo mk4 AWD project. As you are from SE - those are very popular there. Do you have any knowledge about that system ?
Re: Hi There
Posted: 14 Feb 2020, 15:45
by getsome
Sorry have no knowledge about 4wd controllers
Re: Hi There
Posted: 17 Feb 2020, 01:51
by amplified
I know of one awd conversion happening in Uk right now, is thst you , or you do it also?
Re: Hi There
Posted: 17 Feb 2020, 03:39
by Stevebe
I’m certain you will fit right in we are z collective that shares and helps its fellow members
Nice to meet you
Re: Hi There
Posted: 18 Feb 2020, 02:18
by paxtonix
amplified wrote: ↑17 Feb 2020, 01:51
Nope. In not from UK. I saw also on FB some post from UK over converting 2.5 turbo silver sedan to AWD. But the point is parts on foto , that are presented are not the right one for EUDC platform, so that guy will never finish that project.
