Hi There
Newly activated users can post here
getsome
Hi There
Post by getsome »
I´m a 41 year old electronics engineer that works with root cause analysis at one of the biggest electronic companies in my Sweden , I hope that my knowledge in electronics will help someone here , I have also been a huge fan of Ford cars since 1998.
Re: Hi There
Be very welcome to our small (but growing) community here! As i am also adicted to electronics (even i'm not an engineer) i guess we have some commons :)
Are there any special interests of yours? Any projects?
getsome
Re: Hi There
Post by getsome »
Hi.
The only project for the car is in idle right now , but I had plans to try to build some kind of a translator with elm327 and arduino to see the soot % and dpf % loadings on my IPC , or atleast to make a dpf symbol appear during a regen.
Other non relating project I built in the past is an Arduino controller for my wood burning Furnace to optimize the wood burning / gasification process in an optimal rate , this unit basically measured the exhaust temp by the means of a K Type thermocoupler , this information was then used to control primary and secondary air inlet valves with stepper motors so nothing really to do with cars :)
Re: Hi There
My passion are Ford navigation systems, especially the FX, NX and MCA. Did a lot with them, and publish a lot of information and repairs. I also run a wiki dedicated to Ford Mondeo. Besides electronics, microcontrollers and programming is another passion of mine.
ronald0001
Re: Hi There
Post by ronald0001 »
hi...and i am the newbi here in tge forom...tey to learn...my project is a carpc wich finaly should replace the original satnv...in my kind the fx...inc can-bus
paxtonix
Re: Hi There
Post by paxtonix »
getsome wrote: 06 Feb 2020, 06:05 I´m a 41 year old electronics engineer that works with root cause analysis at one of the biggest electronic companies in my Sweden , I hope that my knowledge in electronics will help someone here , I have also been a huge fan of Ford cars since 1998.
Might be I will need your help with Haldex controler in my Mondeo mk4 AWD project. As you are from SE - those are very popular there. Do you have any knowledge about that system ?
Tourist
getsome
Re: Hi There
Post by getsome »
Sorry have no knowledge about 4wd controllers
amplified
Re: Hi There
Post by amplified »
I know of one awd conversion happening in Uk right now, is thst you , or you do it also?
User avatar
Stevebe
Re: Hi There
Post by Stevebe »
I’m certain you will fit right in we are z collective that shares and helps its fellow members
Nice to meet you
Digimod
paxtonix
Re: Hi There
Post by paxtonix »
amplified wrote: 17 Feb 2020, 01:51 I know of one awd conversion happening in Uk right now, is thst you , or you do it also?
Nope. In not from UK. I saw also on FB some post from UK over converting 2.5 turbo silver sedan to AWD. But the point is parts on foto , that are presented are not the right one for EUDC platform, so that guy will never finish that project. :oops:
Tourist
