Probationary wiring diagram for modules of Mondeo mk4 family
hanssi
Starter
Post by hanssi »
Hello everyone,
longer time I have connected several Ford modules (IPC, BCM and FX satnav) at home on the table. Now I have created a scheme for all of you.
The reason why I did it, is that I still did not enjoy sitting in a car. For example you can upload your customized firmware to your modules and much more! That's all in the warm home with a cup of coffee :) Of course you can add also other modules ;)
I have used pictures of connectors from mk4 wiki - hope it´s ok for you Go4IT.
Enjoy! Happy testing!
Artist
Re: Probationary wiring diagram for modules of Mondeo mk4 family
Post by Artist »
Super
User avatar
Stevebe
Post by Stevebe »
hanssi wrote: 28 Jan 2020, 16:57 Hello everyone,
Looking good I had same idea last year, all working I’ll get a few pictures and post
Digimod
hanssi
Starter
Post by hanssi »
The box from cake fits good :lol:
tomy75
Post by tomy75 »
Perfect 🙂
paxtonix
Post by paxtonix »
even for a moment it did not cross my mind that someone might have a problem with connecting modules all together. Your schematic is perfect for developers. Good job
BTW - what program did you use to mark connections ? don't tell me it is paint :oops:
Tourist
hanssi
Starter
Post by hanssi »
paxtonix wrote: 28 Jan 2020, 22:50 even for a moment it did not cross my mind that someone might have a problem with connecting modules all together. Your schematic is perfect for developers. Good job
Yes, Ms Paint 3D :roll:
avladimir
Starter
Post by avladimir »
Excellent idea, thanks!
I was super-lazy and I took a dashboard wiring loom and connected the BCM, IPC, HVAC, SRM, ACM and SASM to it :) But your approach is by far less messy than mine.
hanssi
Starter
Post by hanssi »
avladimir wrote: 29 Jan 2020, 19:10 Excellent idea, thanks!
Thanks. I have no free wiring loom at home, otherwise it would turn out the same way :lol:
Gwe89
Post by Gwe89 »
Is preface bcm same pin out
