difference in digital speed
tomy75
Post by tomy75 »
you know there is a difference in MAIN file?
Re: difference in digital speed
What do you mean?
One is the current and the other the set speed.
DGAlexandru
Post by DGAlexandru »
Or do you mean difference between Speed Gauge and Digital Speed?
If YES, then it is normal - all auto manufactures do it, mainly to allow you to use different sizes for your wheels without having the real speed bigger than the one shown on the gauge - with the condition to use one of the recommended size for the tires.
tomy75
Post by tomy75 »
in one version the speed is also shown at the top right and at the other only at the bottom
peter
Starter
Post by peter »
Was wrong positioning of dig speed when cruise control was activated. Probably was More simple to remove the digital speed when CC was active.
tomy75
Post by tomy75 »
different FW digital speed is installed on each of the pictures, the difference is in the speed display at the top right
paxtonix
Post by paxtonix »
tomy75 wrote: 31 Dec 2019, 14:12 you know there is a difference in MAIN file?
Yes your right, also when you turn the DS off , the CC indicator will also disappear.
This parameter is read from pid VSS - this is the function entered in main under DS.
Tourist
tomy75
Post by tomy75 »
and where is the address?
paxtonix wrote: 31 Dec 2019, 19:56
[/quote]
