IPC Software
paxtonix
Re: IPC Software
Post by paxtonix »
tomy75 wrote: 22 Jan 2020, 17:54 I need Motral mod 1007 or 1010...
Its this FW available?
Can you help me?
Thenx
PM me
Tourist
tomy75
Re: IPC Software
Post by tomy75 »
i need remove airbag control light from version mFL
i have preFL car and put in midFL ipc
all works fine except for the airbag light
exist patch midFL ipc in preFL car with all´m0tra l addons?
thenx
sanndo
Re: IPC Software
Post by sanndo »
Attached is all readable ASCII content from 1122 mod
All menus, languages, extras
Mexanukk
Re: IPC Software
Post by Mexanukk »
Is there a firmware with acc fix for FL in pre FL?
tomy75
Re: IPC Software
Post by tomy75 »
Hello
is there a version of m0tral's fw 1007? does anyone have it?
Solltex
Starter
Re: IPC Software
Post by Solltex »
IPC Software not dump facelift c+, write "Failed to get security access" ? Have mot ral full upgraded facelift c+, maybee can someone dump?
DGAlexandru
Re: IPC Software
Post by DGAlexandru »
I've heard that some newer "M0t ral" versions cannot be reprogrammed with different software, so maybe they changed the "encryption" key.
One way would be to use JTAG to dump the Main FW.
Ursadon never gave me access to IPC Updater source code so even if we dump the new FW by JTAG and decompile it to find the new SEED algorithm, we won't be able to have a new IPC Updater version to connect to C+
An option would be to write by JTAG a normal Main FW, then use IPC Updater or UC DS to put the new M0t ral version back.
Solltex
Starter
Re: IPC Software
Post by Solltex »
its not big problem, but in mot ral FW ligth mod, its looking good :)
Artist
Re: IPC Software
Post by Artist »
I have solved a similar problem a few times.
It was a test and writing of several versions of the modified firmware.
After the update, the common version 1007 could not be written via the vbf loader or IPC uploader.
Convers + didn't work properly, even blinked, or restarted regularly.
The solution was to write the modified firmware via UCDS.
In the IPC Converse + folder, select the correct version and enter.
This option probably doesn't work for UCDS clones, and that's how it should be.
It can't all be free.
I explain this by rewriting some parts outside the range of addresses that are listed for writing the calibration file ...
I even came up with an easy way to protect convers + firmware from an IPC updater. So at least in front of the commonly available equipment for a few euros. However, it has a catch, no further write firmware is possible via UCDS and IDS ...
Solltex
Starter
Re: IPC Software
Post by Solltex »
I upgrade with UCDS clones from IPC Converse folder, any problem, prefacelift and facelift
