Gwe89
Post by Gwe89 »
Found something intresting just need to edit the rest of the background
Background changing with themes
Gwe89
Post by Gwe89 »
Done
Gwe89
Post by Gwe89 »
Fully found it now background changes with theme colour
Gwe89
Post by Gwe89 »
Something fresh, seems the forum is dead these days
marekrbk
Post by marekrbk »
Solltex
Starter
Post by Solltex »
Have little problem, maybee can someone help?
Why logo in first theme in c+ good, but how change second theme in c+ have very bad logo? Try all in imagehacker section, theme1fl, theme2fl, theme m and all, result same.
DGAlexandru
Post by DGAlexandru »
Theme in ConversHacker for PreFl / mFL is bad.. as it uses Theme from FL that is slight different.
You should use CustomBGR option... to have embedded in the image's header the BGR table derived from image - it is explained in this topic how to do it.
Solltex
Starter
Post by Solltex »
DGAlexandru wrote: ↑28 Aug 2021, 09:32 Theme in ConversHacker for PreFl / mFL is bad.. as it uses Theme from FL that is slight different.
yes, I'm using 1.3.2v,, and bad route how generate vbf flash file from walpapers section, generate before 120000, need more latest version CH :(
Solltex
Starter
Post by Solltex »
hey,
what is it purple dots, not at all logo, but on some logo
Your problem is a different one: You show an MK5 on an MK4-IPC, this can't work! :lol:
