Found something intresting just need to edit the rest of the background
Background changing with themes
Done
Fully found it now background changes with theme colour
Something fresh, seems the forum is dead these days
next level https://youtu.be/Mv-J3SzRwK0
Have little problem, maybee can someone help?
Why logo in first theme in c+ good, but how change second theme in c+ have very bad logo? Try all in imagehacker section, theme1fl, theme2fl, theme m and all, result same.
- Pro
Theme in ConversHacker for PreFl / mFL is bad.. as it uses Theme from FL that is slight different.
You should use CustomBGR option... to have embedded in the image's header the BGR table derived from image - it is explained in this topic how to do it.
yes, I'm using 1.3.2v,, and bad route how generate vbf flash file from walpapers section, generate before 120000, need more latest version CHDGAlexandru wrote: ↑28 Aug 2021, 09:32 Theme in ConversHacker for PreFl / mFL is bad.. as it uses Theme from FL that is slight different.
hey,
what is it purple dots, not at all logo, but on some logo
Your problem is a different one: You show an MK5 on an MK4-IPC, this can't work!
