Mondeo 4 Simulator for testing IPC on bench
DGAlexandru
Re: Mondeo 4 Simulator for testing IPC on bench
Post by DGAlexandru »
STN2120 might use other kind of response that isn't implemented in "check for ready read" routine...
I'll ask a friend to lend me his STN as I think his is based on this 2120 version and make the needed changes.
User avatar
Stevebe
Post by Stevebe »
just a note my
original ELS27 (from RU) works 38400
one of my CM327 works but slow 9600 second unit not work earlier version
both tunnel rAT work 38400
FOUND this utill
ELS27Baudrate.zip
Digimod
sanndo
Post by sanndo »
China els27 - 2000000
amplified
Post by amplified »
Yes, tested on 38400 -connects but, commands bug it and can't shine
Solltex
Starter
Post by Solltex »
Im update always convers on car, and today try test on bench. Connect 12+ on pin 32, ground pin 6, acc pin 4, but no acc, only logo light 🥴, same prefacelift and facelift, where problem?
ZvonimirG
Starter
Post by ZvonimirG »
Need can massage with ignition state to switch on IPC
amplified
Post by amplified »
Search the forum, plenty of mentions of can message for ignition on and other stuff
Solltex
Starter
Post by Solltex »
all undestand, send from ucds can, 048 c0 18 78 09 29 02 e0 a0
Gwe89
Post by Gwe89 »
Does this work with Bluetooth elm327 or just USB
Solltex
Starter
Post by Solltex »
ucds usb cable
