Mondeo 4 Simulator for testing IPC on bench
DGAlexandru
- Pro
Re: Mondeo 4 Simulator for testing IPC on bench
STN2120 might use other kind of response that isn't implemented in "check for ready read" routine...
I'll ask a friend to lend me his STN as I think his is based on this 2120 version and make the needed changes.
just a note my
original ELS27 (from RU) works 38400
one of my CM327 works but slow 9600 second unit not work earlier version
both tunnel rAT work 38400
FOUND this utill
FOUND this utill
Digimod
China els27 - 2000000
Yes, tested on 38400 -connects but, commands bug it and can't shine
Im update always convers on car, and today try test on bench. Connect 12+ on pin 32, ground pin 6, acc pin 4, but no acc, only logo light
, same prefacelift and facelift, where problem?
Need can massage with ignition state to switch on IPC
Search the forum, plenty of mentions of can message for ignition on and other stuff
all undestand, send from ucds can, 048 c0 18 78 09 29 02 e0 a0
Does this work with Bluetooth elm327 or just USB
ucds usb cable
