Gwe89
Post by Gwe89 »
M0tral removed one of the bars but if have acc it still overlaps the speed, I edited the image for the ptc heater
Drago
Post by Drago »
I edited all the pictures ptc reduced their height but it didn't do anything
User avatar
fryciu
Starter
Post by fryciu »
Hello gentlemen. Have any of you done a station with convers on andriuno?
amplified
Post by amplified »
You mean bench?
User avatar
fryciu
Starter
Post by fryciu »
Yeppp
Gwe89
Post by Gwe89 »
Hey does CH only work on 64bit machines?
DGAlexandru
Post by DGAlexandru »
Hmm, good question :)
Yes, I think so, as it is compiled with 64bit version of gcc...
Gwe89
Post by Gwe89 »
DGAlexandru wrote: 09 Mar 2021, 00:14 Hmm, good question :)
Thought so I tried it on my laptop running win7 32bit and get error
Artist
Post by Artist »
In the latest version of CH 1.4 it is not possible to save images from main and flash. Is it a problem or my fault?
Artist
Post by Artist »
Gwe89 wrote: 14 Jan 2021, 20:49 M0tral removed one of the bars but if have acc it still overlaps the speed, I edited the image for the ptc heater
I've noticed it so far, I have a version that worked perfectly in the city, but I turned on Cruise Control on the highway with a COLD engine and I need to adapt ...
Everything is fine unless the PTC is turned on. Then you need to edit the PTC image.
