User avatar
fryciu
Starter
Post by fryciu »
I know I have S-max mk1
DGAlexandru
Post by DGAlexandru »
OK.. I saw in your messages that you are interested in images for Mondeo 5 IPC.. the one with QNX.
What is with your previous message.. Why do you say the archive is corrupted?
User avatar
fryciu
Starter
Post by fryciu »
checksum error ....... file is corrupted.
User avatar
fryciu
Starter
Post by fryciu »
or I have the wrong password
User avatar
fryciu
Starter
Post by fryciu »
Ok works, I had the wrong password :)
DGAlexandru Mondeo 5 IPC.. the password you gave me for these mk5 files is wrong
DGAlexandru
I'm not into Mondeo 5... so I don't think I gave you any password for those archives.
If ConversHacker archive was corrupted, others would have complain about it. ;) :idea:
User avatar
fryciu
Starter
Post by fryciu »
Everything is ok, I entered the wrong password;)
As for the mk5 password, maybe it was not you. Although I must admit that it would be nice to have them.
Greetings
Drago
Post by Drago »
how to lower the PTC indicator so that the digital speed shows without overlapping the PTC? I was reducing the index, but it did not bring the expected effect
amplified
Post by amplified »
It looks like Glenn replaced the 11th bar(empty) with the ptc symbol. Yours have 11 bars, his has 10 bars. but then you need to remove the 11th bar (full) so it doesn't overlap the heated symbol.
DGAlexandru
I think that the digital speed needs to be moved also because even if you make the PTC smaller, DS will still be over "km/h" or "mls/h".. this is a design problem that was resolved in newer M0 tr al versions.
