I know I have S-max mk1
- Pro
OK.. I saw in your messages that you are interested in images for Mondeo 5 IPC.. the one with QNX.
What is with your previous message.. Why do you say the archive is corrupted?
checksum error ....... file is corrupted.
or I have the wrong password
Ok works, I had the wrong password
DGAlexandru Mondeo 5 IPC.. the password you gave me for these mk5 files is wrong
![Smile :)](./images/smilies/icon_e_smile.gif)
- Pro
I'm not into Mondeo 5... so I don't think I gave you any password for those archives.
If ConversHacker archive was corrupted, others would have complain about it.
![Idea :idea:](./images/smilies/icon_idea.gif)
![Wink ;)](./images/smilies/icon_e_wink.gif)
Everything is ok, I entered the wrong password;)
As for the mk5 password, maybe it was not you. Although I must admit that it would be nice to have them.
Greetings
Greetings
how to lower the PTC indicator so that the digital speed shows without overlapping the PTC? I was reducing the index, but it did not bring the expected effect
It looks like Glenn replaced the 11th bar(empty) with the ptc symbol. Yours have 11 bars, his has 10 bars. but then you need to remove the 11th bar (full) so it doesn't overlap the heated symbol.
- Pro
I think that the digital speed needs to be moved also because even if you make the PTC smaller, DS will still be over "km/h" or "mls/h".. this is a design problem that was resolved in newer M0 tr al versions.
