ronald0001
Post by ronald0001 »
go4it i hope its ok when i use your pic from the wikipage
Go ahead, looks good :D
DGAlexandru
Post by DGAlexandru »
Convers+ IMG Hacker v1.3.1 - 22-01-2020
### Fixed
- VBF file generation
- Custom BGR file saving
- JASC-PAL file parsing
### Improvements
- Moved "Convert Image" to main window
wiesiow2
Post by wiesiow2 »
Hi all
I think this convershacker 1.3.1 didn't work properly. I mean when you create vbf and write location where must be picture, program put on different place what you write.
Rest looks good.
Thank you DGAlexandru
DGAlexandru
Hi wiesiow2,
VBF from Save Image as VBF?
In plain text part of VBF, yes, it doesn't change the adress and size, they are allways 0x30120000 and 0x00020000, as this text part it isn't taken into consideration, it is there for information only.
If you are talking about something else, please explain.
DGAlexandru
OK, found the problem - In the text message I was saying that you need to enter hexadecimal values but I was reading decimal values.
Convers+ IMG Hacker v1.3.2
### Added
- More options related to the creation of VBF file for "Convert Image"
### Fixed
ConversHacker.7z
User avatar
Stevebe
Post by Stevebe »
DGAlexandru wrote: ↑23 Jan 2020, 19:19 OK, found the problem - In the text message I was saying that you need to enter hexadecimal values but I was reading decimal values.
### Added
### Fixed
ConversHacker.7z
Bless you great job
Digimod
Mexanukk
Post by Mexanukk »
How to replace the image in mine "1122-mFL-flash" file?
paxtonix
Post by paxtonix »
Mexanukk wrote: ↑24 Jan 2020, 05:26 How to replace the image in mine "1122-mFL-flash" file?
Read this thread from 1 post and you will know.
Tourist
terragady
Post by terragady »
I have read this thread maybe hundred times already and I can't understand how to change the logo.
EDIT:
did some progress
inserted logo.vbf
I put my own graphic for logo (do not judge, it was my first pic from the desktop :lol: ). I think I have some problems with checksums.
I used the file with already custom logo in it, it is the same flash file for the same main file I have flashed to my convers. I then changed that logo for my own one but I am not sure where do I have to enter the checksum.
Steps I did:
1. Load photo to IrfanView, change pallete to BGR, save pallete.
2. Open CH, load PAL file, Load photo, encode to RLE, save as BIN (changed the last bytes to point flash offset from original vbf logo) or save as vbf and enter flash offset in the popup and then just extract that logo from vbf.
3. Open original flash vbf with custom logo in CH, check when custom logo starts.
1122vFL-flash.vbf
4. Open original flash vbf in HxD, point where logo starts from point 3, insert in that place my own bin file and save.
inserted logo.vbf
This will work? I can see my logo on CH and it is correct as the original flash file flash offset etc.
