Convers mod boost gauge
vodafone
Re: Convers mod boost gauge
Post by vodafone »
I am watching these Polish forums
One insults the other if he doesn't get something.
What is wrong with someone earning something? The guy in England made me a full mod with ACC FIX and is great.
Thank you
better future with childrens
paxtonix
Post by paxtonix »
vodafone wrote: 27 Nov 2019, 21:31 I am watching these Polish forums
Thank you
Of cours , 🍐 ;)
Tourist
paxtonix
Post by paxtonix »
gwe89 - do you hear yourself ? you are ex C+mod partner. You didn't find anything. You already get everything from C+ Mod... Vin location, HS and MS logs .. and much more as we can see... Bro . Don't fool around your self more like you did. through your fotos , I've already seen you have everything you need. If you cannot figure it out on your own - yeah... not much of my problem.
Other guys are here to educate themselvs.
As @bigi said over who screwed who. I don't believe c+mod screw you up boys. I think your own greed screw you back.
also with the picture, you found nothing - c+hacker found it for you, so ....
want our help ? share things in return. - we are not asking for your money bro...
as @Go4It once said " Give it to public , to get from public "
Tourist
Gwe89
Post by Gwe89 »
paxtonix wrote: 28 Nov 2019, 01:00 gwe89 - do you hear yourself ? you are ex C+mod partner. You didn't find anything. You already get everything from C+ Mod... Vin location, HS and MS logs .. and much more as we can see... Bro . Don't fool around your self more like you did. through your fotos , I've already seen you have everything you need. If you cannot figure it out on your own - yeah... not much of my problem.
Been an ex conversmod partner no we do not get vin locations do you think Alexey will just give that information out hmmm dont think so, same goes with all the canbus logs I had to log for these and the boost one was easy I made a duplicate gateway and logged the ms side, dpf on the other hand took a while as I had to log it for a long time until it did a dpf regen
I have shared things in the past it dont mean I have to share everything because you've spat your dummy out because I have the lot and you want it and I wont share,
I know i dint find logo location i dint say i found it i said i know where logo is and I know convershacker did this hence the picture of convershacker??
If been a conversmod installer gave us the vin locations ect then I would have known where logo was and what to edit to make logo right?
And if I know vin location then I would know how to vin lock it but no I dont know how Alexey works out the 4 bytes that vin lock the mod, I found vin location from unprotected files that I have had for a long time, I now have full mods which are unprotected because my mod is a full package can you see where this is going?
Drago
Post by Drago »
Thank you
stop the fairy tale telling a fruity guy
vodafone
Post by vodafone »
My friend put this :) on C+ screen :o :o :o :o
Calm down guys and get back to work...
We are all here to aid each other in solving technical or electronic challanges.
