Whats new? Waiting for answerGo4IT wrote: ↑20 Feb 2020, 06:51 Now my XPROG is arrived. Will need some time to get familar with it, and find the pins needed for BDM on the PCB and the XPROG, but then i hopefully can rip-off the firmware. What surprises me is that the vendors did not protect their chips against reading from debug-ports. It is a trivial task to do... strange, eh? Even more because no vender ever expect that somebody needs to read firmware but simply overwrite it. If you have it all by hand, it's shurely the best and simplest way to do...
webasto can bus death
Re: webasto can bus death
All done
webasto flash works
https://www.youtube.com/watch?v=Y_sfObb1Cuk
log
https://www.youtube.com/watch?v=LGwgJdPms6E
ucds and 120ohm rezistor
Software 14.19 update works
next test on car
log
next test on car
You terminared end of can bus?
Please describe it.
Please describe it.
No need car, rezistor emulate bcmi
There is not much to describe, it's basic knowledge of CAN Bus. Each side of the two CAN Lines (CAN HIGH and CAN LOW) must be shorted by a 120 ohm resistor. This is called "termination". It will eliminate electrical reflections in the wire and the bus will not work without it.
In a car, those resistors are built in into the modules "spreading" the bus, for the Mondeo those are BCM, PCM and IPC https://mk4-wiki.denkdose.de/artikel/ca ... _im_mondeo
Congrats marek! What files did you put to the VBF Loader? It's hard to read in the video, could you please make a screenshot?
This working good
I have heater from volvo. Hardware is the same but software is different and not working in Ford.
I try to flash it by this software.
All works greats
