Update IPC
amplified
Re: Update IPC
Post by amplified »
As above, the update files for preface can be found in the forum
Usually pam bricks with old version of ucds when you try the update, but when doing with the vbf loader there is no issue.
sanndo
Re: Update IPC
Post by sanndo »
can anyone upload MLoaderPAM.exe?
DGAlexandru
Re: Update IPC
Post by DGAlexandru »
I think it is already on forum.
You can put any complete version of FW for PAM (7G, 8G, AM or BS) if you go with VBF upload, as the hardware is the same.
PAM FaceLift version was still with its own speakers if you had NX or FX.
all35
Starter
Re: Update IPC
Post by all35 »
Hi .I tried upgrade softwareon my friend car via ipcupdater. I'm added sbl /main/flash. Succesful has been uploaded main but flash don't want start downloading.What can be wrong?Can I try download first just main and after this just sbl with flash?
amplified
Re: Update IPC
Post by amplified »
Yes you can upload one at a time.
sanndo
Re: Update IPC
Post by sanndo »
Attach screenshot or log here
all35
Starter
Re: Update IPC
Post by all35 »
At thiscmoment Im still try. I will do later. Still have problem download flash. No issue with main but when I try to download flash program dont start. 0 percent and speed go down to 0kb
all35
Starter
Re: Update IPC
Post by all35 »
all35
Starter
Re: Update IPC
Post by all35 »
sanndo
Re: Update IPC
Post by sanndo »
Did you configure port? And did you use right files for your convers?
