Update IPC
Re: Update IPC
As above, the update files for preface can be found in the forum
Usually pam bricks with old version of ucds when you try the update, but when doing with the vbf loader there is no issue.
Re: Update IPC
can anyone upload MLoaderPAM.exe?
- Pro
Re: Update IPC
I think it is already on forum.
You can put any complete version of FW for PAM (7G, 8G, AM or BS) if you go with VBF upload, as the hardware is the same.
PAM FaceLift version was still with its own speakers if you had NX or FX.
Re: Update IPC
Hi .I tried upgrade softwareon my friend car via ipcupdater. I'm added sbl /main/flash. Succesful has been uploaded main but flash don't want start downloading.What can be wrong?Can I try download first just main and after this just sbl with flash?
Re: Update IPC
Yes you can upload one at a time.
Re: Update IPC
Attach screenshot or log here
Re: Update IPC
At thiscmoment Im still try. I will do later. Still have problem download flash. No issue with main but when I try to download flash program dont start. 0 percent and speed go down to 0kb
Re: Update IPC
Did you configure port? And did you use right files for your convers?
