Update IPC
oscarboiro
Re: Update IPC
Post by oscarboiro »
Ursadon wrote: 14 Feb 2020, 08:46 Linending or lenght wrong
You can put one example the command to write in c?
In Visual Basic I try with vbcr and vbcrlf and Haagen same result. Or I need write string without space?
Kuga MK1 owner
User avatar
Ursadon
Re: Update IPC
Post by Ursadon »
oscarboiro wrote: 14 Feb 2020, 09:28
I'm using Qt framework, so it looks like:
Code: Select all
serial->write(QString("STBR%1\r").arg(baud).toLocal8Bit()); // Set baudrate
After sending a command, you must wait for response ('>' character). If you send another command before ELM reply, you will get such an error
Not native English speaker :cry:
User avatar
Stevebe
Re: Update IPC
Post by Stevebe »
Just wondering if there will be any further up dates to the amazing ipc updater
Digimod
User avatar
Ursadon
Re: Update IPC
Post by Ursadon »
Stevebe wrote: 16 Feb 2020, 23:12 Just wondering if there will be any further up dates to the amazing ipc updater
Thank you for your attention to this project! :)
There is currently a non-public alpha version 2.0 with a new graphical interface and minor bug fixes.
The main functionality was achieved earlier, but I still don’t know what additional functionality the end user needs.
Therefore, so far I decided to start another project - decompilation of the firmware.
User avatar
Stevebe
Re: Update IPC
Post by Stevebe »
Ursadon wrote: 17 Feb 2020, 14:11
I think I speak for the ipc updater software as been one of my single most used tools, so I thank you for the work,
It would be great to take it further but appreciate you have other projects, decompiling firmware is always good,
Keep us posted
Steve
Ps Ursadon I PM you
Digimod
phx-
Starter
Re: Update IPC
Post by phx- »
awesome work, are you able do something for edit maxidot cluster to edit and download and flash it?
never give up !
sanndo
Re: Update IPC
Post by sanndo »
Maybe is a offtopic, but when I update with ipcupdate I don’t have pdc indicators. So I need to update now PAM module. Did anyone know how?
amplified
Re: Update IPC
Post by amplified »
Yes, in some rare cases on preFL cars you need to update the PAM firmware to one that transmits can data from sensors.
sanndo
Re: Update IPC
Post by sanndo »
Ok, but anyone know a method to do that? With elm or els?
Artist
Re: Update IPC
Post by Artist »
sanndo wrote: 23 Feb 2020, 08:17 Maybe is a offtopic, but when I update with ipcupdate I don’t have pdc indicators. So I need to update now PAM module. Did anyone know how?
If the PAM has old software or there is another type of radio, eg. Android, there may be a problem displaying an image or sound.
The prefacelift PAM module has its own buzzer, Facelift goes to the speakers ...
You can do this in different ways:
- I think you don't have UCDS, VCM2, IDS, otherwise you wouldn't ask and it's one way to update the unit and specifically the PAM module ...
- The second is a test version of Forscan Beta, which also includes module updates. Currently the developer has downloaded versions and does not provide updates for fatal beta testing bugs ...
However, getting the old version is not a problem.
However, keep in mind that there may be a problem. Recently, the forum addressed the recovery of the PAM unit after poor updates.
Although I updated about 15 pieces, there was no problem.
