Understanding data structure of "fgs.dnl" file from Nav-FX Update-CD
sanndo
Re: Understanding data structure of "fgs.dnl" file from Nav-FX Update-CD
Post by sanndo »
There is a system languages in fgs.dln too. Attached is PL version
tomy75
Post by tomy75 »
Hello go4it
Can you make fgs.dnl packer?
I need make translate english to slovak...
Thenx
hanssi
Starter
Post by hanssi »
Good idea. I have done it with hex editor but there we need more space for our words. That might be a good way.
sanndo
Post by sanndo »
hanssi wrote: 09 Dec 2020, 15:11 Good idea. I have done it with hex editor but there we need more space for our words. That might be a good way.
Did you just edit in hex and upload to FX? File .dnl need or not checksum?
Somebody need to test what happens when the contents of the FGS.DNL file is patched (edited). Of course the last four bytes of the file should contain a valid CRC-32 checksum of the changed data. I would start with changing the update-progress-messages.
sanndo wrote: 07 Mar 2020, 09:44 There is a system languages in fgs.dln too. Attached is PL version
As all the text messages the radio can display reside in this fgs.dnl file, we can assume that the OMAP application only sends message-IDs to the graphicsboard instead of full text messages or rendered graphics.
tomy75
Post by tomy75 »
In PL version fw its text mesage longer how in EN version how is it possible? if i want to do slovak translation I need more space for translation, similar to PL version
DGAlexandru
Post by DGAlexandru »
You replace the PL version :)
tomy75
Post by tomy75 »
PL its old FW version😐
DGAlexandru
German language usually has long words. Isn't it good enough?
