Gwe89
Pro
Post by Gwe89 »
I have just made a logo with CH using the palette exported from irfanview and put it in main
The main already had a logo and I replaced this logo with the one CH made and this was my result you can see a slight out line of the logo, any ideas?
Pro
Post by Go4IT »
I think i made my point clear as i will not make a business model out whatever i develop. Like the PIN decoder for all FX, NX and MCA i put on my homepage. If somebody of you will make it for money it's completely up to you, but for i will never do. It's pure hobby and fun for me. But never blame me for maybe break your business by giving things public. This is my inner orientation and i will not behave against it.
Again, playing with custom images is not of big interest for me, but reverse engineering what and how it works of course. Therefore i would never aim to give complete solutions here, but more frameworks and methods how to get there.
tomy75
Active member
Post by tomy75 »
Hi guys,
Together with my friend hannsi, we found a way to change images in the easiest way.
with this technique can change all of image in FLASH file and make new startup animation
Pro
Post by Go4IT »
Hey tomy75, hanssi, i wonder why you make so much extra work and created a PDF and don't simply post it here? You seem to be on the right track, but i fear you and most others here make a fatal wrong assumption when you beliefe that memory locations of images are fix. They aren't, at least they differ in the FW version.
I would really prefer that all of you guys try to dig deeper into the code and algos than just playing with pictures. There is so much more interesting stuff inside! Just grab an IDA or Ghidra and start disassembling and learning, share your findings and gain more insides. THATS the kind of teamwork i had in mind when founding this forum...
Gwe89
Pro
Post by Gwe89 »
tomy75 wrote: ↑26 Dec 2019, 22:13 Hi guys,
whit this can change all of image in FLASH file
with this technik make new startup animation
I tried this method and I just get a blank logo screen even after using a custom logo I know that works
hanssi
Starter
Post by hanssi »
Hey Gwe89,
you're doing something wrong.
Just tested and works.
Must be used original main file
8M2T-14C026-CE original from ford.vbf
Gwe89
Pro
Post by Gwe89 »
hanssi wrote: ↑27 Dec 2019, 10:07 Hey Gwe89,
Yes I used mod file that uses just stock logo
Gwe89
Pro
Post by Gwe89 »
I changed 30 12 00 0C and 30 12 00 00
To 30 12 04 0C and 30 12 04 00 and works logos not the best but has worked
hanssi
Starter
Post by hanssi »
Gwe89 wrote: ↑27 Dec 2019, 10:22 I changed 30 12 00 0C and 30 12 00 00
Of course this tutorial is about "How to put a new logo into flash", not for how to change color palette.
Gwe89
Pro
Post by Gwe89 »
hanssi wrote: ↑27 Dec 2019, 10:48
I know
Post Reply
