Disassemble MAC7116 software (Ford IPC)
Disassemble Convers+ firmware 7M2T-14C026-AG using IDA Pro
Pro
Post by Go4IT »
Hey guys, for those who have an IDA Pro at hand, here are the settings to disassemble:
- Open binary image file (extracted from an VBF, for example)
- Set Processor type to "ARM Big-endian [ARMB]"
- Clock on "Processor options" ⇒ "Edit ARM architecture options" and set it to "ARMv4T"
IDA will start interpreting code from 0x0000 onwards. Remember that this is Assembler Nmemonics and not C. IDA Pro is able to do some decompiling, so converting Assembler into C, but that do not result in good readable code, it's just an approach. But, i can do this on subroutines only (for whatever reason...)
Happy hacking!
tomy75
Active member
Re: Disassemble MAC7116 software (Ford IPC)
Post by tomy75 »
Thenx😉
How settings this?
Its main flash file
Pro
Post by Go4IT »
Just use the settings right away. The default is ok.
DGAlexandru
Pro
Post by DGAlexandru »
If you want to see what's happening into RAM, then:
RAM start address: 0x40.000.000 (without dots)
RAM size: 0xC000 (48kb)
ROM start address is 0x5000 - this is were you should load the BIN file that you get from VBF.
In disassembled code, every address with 0xFC.***.*** means is for setting up the ARM or for reading / writing its peripherals (I/O pins, I2C - EEPROM, CAN) or communicating (write operation) with the Epson Display Controller or reading from external flash using its eMIOS interface.
Dumped RAM image of a FaceLift with "Full UC DS Mot Ral" after powering ON Convers (just power applied, no CAN message for Contact ON):
RAM_reset_noIce.bin
Dumped RAM image of a FaceLift with "Full UC DS Mot Ral" after starting Convers (Contact ON):
RAM_booted_noIce.bin
Also, one more thing I see it's missing is the real BootLoader of Convers (0x0 to 0x4FFF). The VBF file for Main Flash does not contain this BootLoader.
PreFaceLift model and FaceLift model have different versions of this BootLoader, but I changed them between with no problem observed.
FaceLift BootLoader:
Boot_FaceLift_BS7T-10849-VH_13Feb2012.bin
PreFaceLift BootLoader:
Boot_PreFL_8S7T-10849-.bin
If you want to add this BootLoader to your BIN file to really see what is going on with a Disassembler, then you should create a new file that has from 0x0 to 0x4FFF this BootLoader and then from 0x5000 to 0xFB000 the BIN from VBF.
And one more thing Tomy75 - your BIN file contains 2 bytes more - I think you forgot to remove the last 2 Bytes from VBF ... this Bytes are used in VBF for CheckSum - you don't need them in IDA.
drobec.eu
Starter
Post by drobec.eu »
I tried to set up IDA pro for Convers firmware, but I couldn't get the results he posted screenshot here ursadon... :(
tomy75
Active member
Post by tomy75 »
DGAlexandru,
thenx for info,you working only with Main vbf file?and how edit Flash vbf file?
Thenx
DGAlexandru
Pro
Only Main VBF.
Flash VBF is no use in a disassembler as it only contains data to be read and then writen in RAM or writen directly on Epson display chip, but mainly because in Main you don't see address pointers to Flash chip directly but by reading the Flash on eMIOS interface (0xFC.***.***)
tomy75
Active member
Post by tomy75 »
How setting desasembly memory oraganization windows?
tomy75
Active member
Post by tomy75 »
i have search for 0xFCxxxxxx or 0x30xxxxxx adress?
Post Reply
