Forscan beta with update support
Re: Forscan beta with update support
Have anybody ever tried to program PATS for keyless vehicles with Forscan? This option was recently added to Forscan, but until yet i never dared to use it
Yes work all Ford cars until the year 2019 also works with many cars with GWM you can check the changelog everything it says there works
Great, thank you!
- Pro
But you can use the function for only one VIN!
The first one you use it for!
.. but then again.. you can change the VIN on the new car before using it .. then change the VIN back to the original one.
Interesting aspect. Means, once you used the PATS function, your Foscan will be locked to the VIN of the car you used it and refuses to do PATS for other cars?
